{"product_id":"lamello-invis-mx2-jointer-set-30mm-stud-pkt-20","title":"Lamello Invis Mx2 Jointer Set (30mm Stud) - (Pkt 20)","description":"\u003cp\u003eThe Lamello Invis Mx2 system delivers a magnet‑driven, completely invisible connector offering exceptional joint strength and premium aesthetics. With no visible openings and the ability to repeatedly open and close the joint via magnetic drive, it’s the perfect solution for high‑end furniture, stairs, moulded workpieces and lacquered panels.\u003c\/p\u003e\u003cp\u003eA pack of 20 x 30mm Invis Mx2 studs, engineered for use with the Lamello Invis Mx2 joining system. These studs form the male side of the connector, used within precisely drilled 12mm holes to create a secure, concealed magnetic joint. The studs work in conjunction with the Invis Mx2 joining element and are tightened or released contact‑free via the MiniMag Mx2 actuator.\u003c\/p\u003e\u003cp\u003eLamello is a world leader in innovative joinery systems, known for Swiss precision, award‑winning engineering and solutions that elevate both productivity and aesthetics. The Invis Mx2 system exemplifies this ethos: a unique, magnetically driven connector delivering high clamping force, speed, and uncompromising visual quality in premium woodworking.\u003c\/p\u003e\u003cp\u003eSpecification\u003c\/p\u003e\u003cp\u003eQuantity: 20\u003c\/p\u003e\u003cp\u003eStud type: Invis Mx2, 30mm\u003c\/p\u003e\u003cp\u003eRequired hole size: Ø12 mm\u003c\/p\u003e\u003cp\u003eJoint clamping force: Up to 250 kg per connector (system) [lamello.com]\u003c\/p\u003e\u003cp\u003eOperation: Magnetic actuation via MiniMag Mx2 at 1200–1500 rpm (system) [lamello.com]\u003c\/p\u003e\u003cp\u003eApplication: Invisible, detachable furniture and panel joinery\u003c\/p\u003e\u003cp\u003eSuitable for: Solid wood, panel materials, and moulded components\u003c\/p\u003e\u003cp\u003eEnhance your setup by pairing these studs with the Lamello Invis Mx2 joining elements, MiniMag Mx2 actuator, and Rasto drilling jig for precision hole alignment and effortless magnetic assembly.\u003c\/p\u003e","brand":"Lamello","offers":[{"title":"Default Title","offer_id":54118851641691,"sku":"508504","price":141.42,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/508504_xl.jpg?v=1789793900","url":"https:\/\/www.axminstertools.com\/products\/lamello-invis-mx2-jointer-set-30mm-stud-pkt-20","provider":"Axminster Tools","version":"1.0","type":"link"}
