Part of the range of accessories and connectors for the Lamello Invis Mx system. The MiniMag Mx houses the rotating magnetic that drives the jointing connectors of the Lamello Invis system, attaching to any standard drill and running at between 120 - 1500rpm. Supplied with a special screwdriver bit to screw the Invis connectors in to the drilled holes.
Lamello
Lamello MiniMag Mx & Driver Bit
| Web Attribute Set | Dowelling Jigs & Accessories |
| EAN Barcode | 7640129662739 |
