These Lamello Zeta 5mm positioning pins are for use alongside the Lamello Zeta P2 Biscuit Jointer, to accurately cut P-System grooves that are required in the middle of a surface. Using a CNC machine, drill two 5mm holes spaced at 101mm apart, and insert the pins. Finish the cut by inserting the Lamello Zeta into the drilled holes to achieve precise alignment.
Web Attribute Set Biscuit Jointer Accessories
EAN Barcode 7640129668373
