{"product_id":"lamello-zeta-p2-biscuit-jointer-in-systainer-case-with-diamond-blade","title":"Lamello Zeta P2 Biscuit Jointer in Systainer Case with Diamond Blade","description":"\u003cp\u003eThe Zeta P2 is the second generation Zeta fitted with the new P-system depth adjuster. The Zeta offers more than the standard biscuit jointer, with an undercut function to allow for the fitting of special concealed Clamex P connectors that slide into the \u003cspecial id=\"2\"\u003e\u003c\/special\u003eT\u003cspecial id=\"2\"\u003e\u003c\/special\u003e slot produced. The connector also clamps, so no additional clamping methods are required. Almost totally concealed, the only visible sign is a single 6mm hole, making it ideal for many applications such as furniture, shop fitting and exhibitions. It is also suitable for solid wood and man-made boards, overcoming many design issues.\u003c\/p\u003e\u003cp\u003eUnique to Lamello, the jointer has a special vertical mechanical drive (VMD) engaging when the jointer is at full plunge, moving the cutter up and down in one full turn and only then disengaging to produce the \u003cspecial id=\"2\"\u003e\u003c\/special\u003eT\u003cspecial id=\"2\"\u003e\u003c\/special\u003e slot to accept the special Clamex biscuit. The undercut function can be switched off and a 7mm slot will be produced; a \u003cspecial id=\"2\"\u003e\u003c\/special\u003eBisco\u003cspecial id=\"2\"\u003e\u003c\/special\u003e biscuit can then be used. Replace the special blade with a 4mm biscuit blade and use as a standard biscuit jointer. The new P-System depth adjuster has five settings for the ever growing range of Clamex connectors and when used with a standard biscuit jointing blade.\u003c\/p\u003e\u003cp\u003eAs with all Lamello products, design and build are of the highest quality. Other features include precise plunge with clear depth setting and jointer fences with flush sides to make positioning simple; the fence fits with \u003cspecial id=\"2\"\u003e\u003c\/special\u003eV\u003cspecial id=\"2\"\u003e\u003c\/special\u003e grooves for accuracy and clear angle scale.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eThe jointer is supplied in a Systainer case with stop square, suction stub 36 mm, disc for angles, spacer 2 + 4 mm, tools, Clamex P drill jig incl. drill bit.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Lamello","offers":[{"title":"Default Title","offer_id":54117979455835,"sku":"508552","price":1436.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/508552_xl.jpg?v=1790081791","url":"https:\/\/www.axminstertools.com\/products\/lamello-zeta-p2-biscuit-jointer-in-systainer-case-with-diamond-blade","provider":"Axminster Tools","version":"1.0","type":"link"}
