Six decades after inventing the original biscuit jointer, Lamello has developed a cordless Zeta P2. This cordless Zeta P2 adds a new dimension to an already magnificent invention. It is designed and produced with the same care and precision as Lamello’s mains powered machines. Here you have a Swiss made cordless Zeta P2 with the freedom and convenience of a battery powered tool combined with all the functions and features of the mains powered version.
The Zeta P2 features diamond tipped blade and a special undercut function, unique to Lamello. This function produces a T-slot allowing you to use Clamex P concealed clamping connectors and many other types of useful and unique connectors such as Tenso and Bisco. These connectors can save a great deal of time when making cabinets and similar furniture items. There is no need for clamps and unsightly screws, panels go together quickly, accurately and securely. The P-System depth adjuster has five settings for the ever growing range of Clamex connectors.
The undercut function can be switched off and a 7mm slot will be produced for a 'Bisco' biscuit. Replace the special blade with a 4mm biscuit blade and use the Zeta P2 for standard biscuit jointing.
As with all Lamello products, design and build are of the highest quality. Other features include precise plunge with clear depth setting and jointer fences with flush sides to make positioning simple. The fence fits with 'V' grooves for accuracy and clear angle scale.
An added bonus comes in the form of the Lamello batteries. These are LIHD and have the common CAS (Cordless Alliance System) fitting. The CAS fitting is now the standard for over 30 European manufacturers (and growing). CAS already includes Mafell and Metabo.
Note this is a body only tool in a Systainer T-LOC case and supplied without batteries or charger.
Battery Voltage 18 V
Dust Extraction 36 mm Outlet
Rating Trade/Professional
Blade Diameter 100 mm
Sound Power Level LwA [Uncertainty K] 90 dB(A) [3.0 dB]
Battery Type LIHD
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 79 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 0.7 m/s² [1.5 m/s²]
Cutter Speed 9,000 rpm
Web Attribute Set Biscuit Jointers
EAN Barcode 7640348846965
