{"product_id":"leigh-b975-box-joint-beehive-jig","title":"Leigh B975 Box Joint \u0026 Beehive Jig","description":"\u003cp\u003eA box joint, also known as a corner finger joint or occasionally a comb joint, as the name implies is an ideal joint when constructing wooden boxes. A classic dovetail joint is beautiful and strong. However, a box-joint is much more appropriate when making boxes from plywood or other man-made boards. It is equally suitable for use with natural timber resulting in an attractive, alternating grain pattern at the corners. The finger construction produces a huge glue surface area, making a box joint as strong if not stronger than a dovetail joint.\u003c\/p\u003e\u003cp\u003eThe Leigh B975 multipurpose box joint jig comes complete with a comprehensive instruction booklet. It is a simple, easy-to-use jig for making 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (12.7mm) and 3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (19mm) box joints on boards up to 20.6mm (13\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) thick.\u003c\/p\u003e\u003cp\u003eYou can use the jig with a handheld router or on a router table. The only stipulation being the router or table must be able to take a Leigh threaded guide bush (see Leigh Adaptors for Threaded Guide Bushes). The Leigh e10 guide bush supplied with the jig ensures you can achieve perfectly fitting box joints every time.\u003c\/p\u003e\u003cp\u003eThe maximum board width is up to 246mm (1.7\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) using the full jig width or up to 452mm (17.13\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e) wide using the step-over procedure (handheld router only).\u003c\/p\u003e\u003cp\u003eFor beekeepers, the design of the B975 helps produce several sizes of beehive supers using 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (12.7mm) and 3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e (19mm) joints.\u003c\/p\u003e\u003cp\u003eStandard Equipment included: glass-reinforced nylon template, e10 elliptical router guide bushing, pin wrench for e10 bushing adjustment, TCT straight bit 160, 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e x 1.1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e, 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e and 3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e adjustable side stops, 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e and 3\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e step-over cams for wide board routing and 10 x 25mm Phillips head screws for mounting.\u003c\/p\u003e","brand":"Leigh","offers":[{"title":"Default Title","offer_id":54118303138139,"sku":"104712","price":53.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104712_xl.jpg?v=1789774534","url":"https:\/\/www.axminstertools.com\/products\/leigh-b975-box-joint-beehive-jig","provider":"Axminster Tools","version":"1.0","type":"link"}
