{"product_id":"leigh-d4rm-pro-dovetail-router-jig-package-deal","title":"Leigh D4RM Pro Dovetail Router Jig - PACKAGE DEAL","description":"\u003cp\u003eThis really is a superb package which contains the award winning D4RM Pro dovetail jig plus the very effective VRS Vacuum \u0026amp; Router Support which not only extracts the waste but makes using the jig safer and easier. Also included is an excellent Leigh 8mm Shank 12 Piece Cutter Set to carry out a wide range of different joint sizes.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eLeigh D4RM Pro Dovetail Jig\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eIn a class of its own, the Leigh D4RM offers; through, half blind and sliding dovetails with infinite adjustment of pins and tail widths. A precision one-piece extruded aluminium body, with non-marring textured clamping surfaces and machined-in side stops adds extra rigidity and accuracy. The D4RM, produces joints with that classic hand-cut look. The jig is supplied with the more robust 8mm diameter shank cutters. Adjustment scales are calibrated in metric (Not available in imperial). Included with the jig is the 711TP guide bush which fits directly onto many popular routers; other routers may need different guide bush and adaptor. The very full specification includes: 8\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 14\u003cspecial id=\"8\"\u003e\u003c\/special\u003e dovetail cutters, 5\/16\u003cspecial id=\"1\"\u003e\u003c\/special\u003e diameter straight cutter, cam action material clamps, guide bars for cutting sliding dovetails and mounting hardware. Detailed instructional videos and comprehensive user guides are available online.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eLeigh VRS Vacuum \u0026amp; Router Support\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eRevolutionary dust free Routing for a safer, cleaner workshop.\u003c\/p\u003e\u003cp\u003eThe revolutionary Leigh VRS Vacuum and Router Support, provides almost 100% dust and chip collection, as well as amazing full width router support. The VRS is a must for all Leigh Dovetail Jig owners. Available for all Super Jigs, D1600, D4R \u0026amp; all 24\u003cspecial id=\"1\"\u003e\u003c\/special\u003e D-series Jigs.\u003c\/p\u003e\u003cp\u003eThe router is positioned between the control arms attached to the vacuum chute below. The arms are adjustable to suit any size router base. The vacuum chute glides effortlessly from side to side on nylon rollers and automatically follows the router when routing the joint or when the router is parked off to the\u003c\/p\u003e\u003cp\u003eside. The chute is always in the perfect position to catch the chips being thrown out by the high-speed router bit action. Chips and sawdust are drawn into the vacuum chute and down through the vacuum hose. Each VRS comes complete with two adaptors to fit all popular vacuum hose\u003c\/p\u003e\u003cp\u003esizes from 1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e to 2.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e. The VRS can be used with a small shop vac or large built in system.\u003c\/p\u003e\u003cp\u003eThe VRS is a full width router support. When the work piece has been routed on one side of the jig, the router can be effortlessly moved to the other side of the jig and parked while the work piece is being changed. There is no need to remove the router from the jig.\u003c\/p\u003e\u003cp\u003eAs the vacuum box is always in perfect position relative to the router bit, the dust and chips are drawn into the chute and vacuum hose.\u003c\/p\u003e\u003cp\u003eThe dust chute rides beneath the router support beam. Control arms ensure accurate positioning of the chute and the size and shape of the chute ensures total waste collection regardless of bit size or joint type being routed.\u003c\/p\u003e\u003cp\u003eThe VRS will work with almost any shop vac or large vac system. Two adaptors are included with every VRS to handle hose sizes from 1\u003cspecial id=\"1\"\u003e\u003c\/special\u003e to 2.1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eLeigh 8mm Shank 12 Piece Cutter Set\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003eThe larger cross section (58% more mass) of 8mm shank bits makes them considerably stronger than 1\/4\u003cspecial id=\"1\"\u003e\u003c\/special\u003e shank bits, resulting in smoother, faster cuts with less chatter and greater safety.\u003c\/p\u003e\u003cp\u003e12 piece set contains Leigh cutters 50-8, 60-8, 70-8, 75-8, 101-8, 112-8, 128-8, 90,100, 150,160 \u0026amp; 172-8.\u003c\/p\u003e\u003cp\u003ePlease note: Set contain 1\/2\u003cspecial id=\"1\"\u003e\u003c\/special\u003e shank cutters not suitable for use with the Leigh Super jigs.\u003c\/p\u003e","brand":"Leigh","offers":[{"title":"Default Title","offer_id":54249968107867,"sku":"718476","price":893.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/718476_xl.jpg?v=1791192360","url":"https:\/\/www.axminstertools.com\/products\/leigh-d4rm-pro-dovetail-router-jig-package-deal","provider":"Axminster Tools","version":"1.0","type":"link"}
