Leigh
Leigh HSS Spiral Upcut Router Cutters
SKU: 475709
£17.68
£14.73 Excl. VAT
  • Two flute spiral upcut bits, smoother finish & reduced tearout
  • Spiral upcut cuts cleaner & faster
  • Ground from one piece solid High Speed Steel
The spiral upcut design of these router cutters ensures a very clean fast cutting action, dramatically reducing tearout and leaving a smooth finish. These cutters are particularly suitable for cutting finger joints on routing jigs. The spiral design gives a smooth shear cutting action, whilst the upward direction results in rapid waste removal.
N.B please ensure your workpiece is securely clamped when using upcut bits.
Shank Diameter 8 mm
X = Depth of Cut 22.2 mm (7/8")
D = Overall Diameter 8 mm (5/16")
Leigh Part No. 170 Web Attribute Set: Spiral Router Cutters D: 8 X: 22.2
