Low odour Palette Wood Dye is a water based acrylic dye with good light resistance and a formula suitable for use on most new or stripped woods. Being water based it is slower to dry than spirit or oil based dyes, an advantage on larger flat areas, as the dye is easy to work and equalise resulting in a uniform surface. Available in wood colours, all of which can be mixed to give intermediate colours or altered by the addition of concentrated water soluble dyes (approximate coverage 500ml to 4 - 6m
Liberon
Liberon Palette Wood Dye
| Coverage | 8 m to 16 m per litre |
| Application Method | Brush Foam Applicator |
| Drying Time | 2 hours |
| Clean Up | Water |
| Available Sizes | 250 ml |
| Web Attribute Set | Wood Dyes & Colourants |
| EAN Barcode | 3282391062882 |
