Low odour Palette Wood Dye is a water based acrylic dye with good light resistance and a formula suitable for use on most new or stripped woods. Being water based it is slower to dry than spirit or oil based dyes, an advantage on larger flat areas, as the dye is easy to work and equalise resulting in a uniform surface. Available in wood colours, all of which can be mixed to give intermediate colours or altered by the addition of concentrated water soluble dyes (approximate coverage 500ml to 4 - 6m).
Coverage 8 m to 16 m per litre
Application Method Brush Foam Applicator
Drying Time 2 hours
Clean Up Water
Dye Base\Type Water Based
Usage Interior
Available Sizes 250 ml
EAN Barcode 3282391062882
Accessories
  • Chestnut Jenny Brushes Chestnut Jenny Brushes
    £3.68 - £4.98
  • 36 Assorted Disposable Paint Brushes 36 Assorted Disposable Paint Brushes
