A simple kit comprising a 7mm diameter brass tube with a decorative stud at one end and a top entry hole fitting for a cord at the other. The top can be unscrewed allowing the cord to be inserted and knotted within the fitting. This is a great way of using up your offcuts to produce some unusual designs for light pulls and blind pulls.Our project kit blanks would make a great choice of material for producing some colourful designs. Choose from gold or chrome finish. Overall length 53mm when assembled.
Difficulty Beginner
Drill Bit Required 7 mm
Bushing Set Order No. 8.5mm O/D (as supplied with mandrel) (100793)
Minimum Blank Size 16 mm to 25 mm square x 38 mm long
Finish Gold Plated
Web Attribute Set Project Kits
EAN Barcode 5052511059362
