A simple kit comprising a brass tube with a decorative finial at one end and a top entry hole for a single cord at the other. The top can be unscrewed allowing the cord to be threaded and knotted within the fitting. This is a great way of using up your offcuts to produce some unusual designs for light pulls, plumb bobs, blind pulls and pendulums. We are sure the more imaginative among our customers will find other creative ways of using this kit. The brass tube, for instance, could be swapped for one of our 7mm pen kit tubes which are 16mm longer and available in packs of 20. Our project kit blanks would make a great choice of material for producing some colourful designs.
Difficulty Beginner
Drill Bit Required 7 mm
Bushing Set Order No. 8.5mm O/D (as supplied with mandrel) (100793)
Minimum Blank Size 16 mm to 25 mm square x 38 mm long
Web Attribute Set Project Kits
EAN Barcode 5052511066025
