This tough, foldable lamp is about as versatile as it gets. Whether you’re working in a dark corner of a loft or just want a simple desk lamp next to your laptop, the LC7000 provides the illumination. It features five light settings, a foldable design for easy positioning, a magnetic base and a hanging hook. It is both a powerful strip light and a directional torch.
Simple to use; press the power button for the white lights and hold down the power button for the red lights. The torch can either be used cordless, attached to the computer/laptop or attached to the mains via the USB.
The 24 COB LEDs (16 white, 8 red) provide cool, shadow free light. The five light settings include; bright and soft white strip light, bright red strip light and flashing red strip light, as well as a small bright white flashlight at the tip. The integral Li-on battery gives a runtime of up to 12 hours and a 1m USB cable is included for charging.
Keep one in the toolbox, one in the car for emergencies, one in the tent and one in the kitchen drawer.
Run times approximately:
Bright white LED = 3 hours
Soft white LED = 10-12 hours
Red LED = 12 hours
Folded: 148mm x 47mm x 35mm, extended: 270mm x 47mm x 35mm.
Battery Capacity 1,200 mAh
Battery Voltage 3.7 V
Batteries Integral
Battery Type Li-ion
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5060576966174
