This professional long reach task lamp with a slimline design and swivel head is perfect for illuminating a bench or work desk. The long articulated arm allows you to position the lamp head exactly where it’s needed. A built-In dimmer switch controls the brightness to suit the task in hand. Ninety, energy efficient, white SMD LEDs produce 6,000 to 7,000K light, yet use only 14W. The LEDs never need replacing and produce shadow free cool light. The head swivels offering lighting over a narrow area or a wide spread over an entire tabletop. Supplied with table clamp (max table thickness 65mm).
LightCraft
LightCraft Long Reach Slimline Task Lamp
| Web Attribute Set | Lighting |
| EAN Barcode | 5060576965054 |
