{"product_id":"lighthouse-800-led-torch-rechargeable-usb-powerbank","title":"Lighthouse 800 LED Torch Rechargeable USB Powerbank","description":"\u003cp\u003eThe Lighthouse Focus 800 is a high-performance LED torch delivering up to 800 lumens of bright, reliable light. It features three lighting modes—High, Low, and Strobe—plus a variable dimming function for precise brightness control. The focus adjustment allows you to switch between a tight spot beam and a wide floodlight, making it ideal for a range of tasks.\u003c\/p\u003e\u003cp\u003eBuilt with a lightweight, anodised aluminium body, the torch is both durable and weather-resistant to IP54 standards, offering protection against dust and water.\u003c\/p\u003e\u003cp\u003eA tail light charging indicator provides clear battery status:\u003c\/p\u003e\u003cp\u003eRed: Charging needed\u003c\/p\u003e\u003cp\u003eBlue: Charging in progress\u003c\/p\u003e\u003cp\u003eGreen: Fully charged\u003c\/p\u003e\u003cp\u003eThis tail light can also be set to green night vision mode, perfect for map reading in low-light conditions.\u003c\/p\u003e\u003cp\u003ePowerbank Functionality\u003c\/p\u003e\u003cp\u003eThe Focus 800 doubles as a portable powerbank, capable of charging small electronic devices such as phones or MP3 players (using the device’s own USB charging cable). To activate:\u003c\/p\u003e\u003cp\u003eCycle the tail-cap switch until the green LED is on.\u003c\/p\u003e\u003cp\u003ePress the tail-cap switch twice quickly—green flashing indicates powerbank mode is active.\u003c\/p\u003e\u003cp\u003eConnect your device via the USB output on the torch.\u003c\/p\u003e\u003cp\u003eEnsure the torch is switched off during charging to minimise recharge time.\u003c\/p\u003e\u003cp\u003eDisconnect once charging is complete to conserve battery.\u003c\/p\u003e\u003cp\u003eNote: Compatible with most USB-charged devices. Some manufacturers use proprietary cables with authentication chips that may not support third-party charging.\u003c\/p\u003e\u003cp\u003eSpecifications:\u003c\/p\u003e\u003cp\u003eLight Source: High-performance LED\u003c\/p\u003e\u003cp\u003eBrightness: 800 \/ 240 lumens\u003c\/p\u003e\u003cp\u003eRun Time: 3 \/ 8 hours\u003c\/p\u003e\u003cp\u003eBeam Distance: 100m\u003c\/p\u003e\u003cp\u003eBattery: Rechargeable 3.7V 2600mAh Li-ion\u003c\/p\u003e\u003cp\u003eCharge Time: 5 hours\u003c\/p\u003e\u003cp\u003eWater Resistance: IP54\u003c\/p\u003e\u003cp\u003eDimensions: 154 x 37 \/ 31.8 mm\u003c\/p\u003e\u003cp\u003eWeight: 157g (excluding battery)\u003c\/p\u003e\u003cp\u003eIncludes: USB charging cable and car charger.\u003c\/p\u003e","brand":"Lighthouse","offers":[{"title":"Default Title","offer_id":54118817235291,"sku":"113774","price":45.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/113774_xl.jpg?v=1789792406","url":"https:\/\/www.axminstertools.com\/products\/lighthouse-800-led-torch-rechargeable-usb-powerbank","provider":"Axminster Tools","version":"1.0","type":"link"}
