The Lighthouse Focus 800 is a high-performance LED torch delivering up to 800 lumens of bright, reliable light. It features three lighting modes—High, Low, and Strobe—plus a variable dimming function for precise brightness control. The focus adjustment allows you to switch between a tight spot beam and a wide floodlight, making it ideal for a range of tasks.
Built with a lightweight, anodised aluminium body, the torch is both durable and weather-resistant to IP54 standards, offering protection against dust and water.
A tail light charging indicator provides clear battery status:
Red: Charging needed
Blue: Charging in progress
Green: Fully charged
This tail light can also be set to green night vision mode, perfect for map reading in low-light conditions.
Powerbank Functionality
The Focus 800 doubles as a portable powerbank, capable of charging small electronic devices such as phones or MP3 players (using the device’s own USB charging cable). To activate:
Cycle the tail-cap switch until the green LED is on.
Press the tail-cap switch twice quickly—green flashing indicates powerbank mode is active.
Connect your device via the USB output on the torch.
Ensure the torch is switched off during charging to minimise recharge time.
Disconnect once charging is complete to conserve battery.
Note: Compatible with most USB-charged devices. Some manufacturers use proprietary cables with authentication chips that may not support third-party charging.
Specifications:
Light Source: High-performance LED
Brightness: 800 / 240 lumens
Run Time: 3 / 8 hours
Beam Distance: 100m
Battery: Rechargeable 3.7V 2600mAh Li-ion
Charge Time: 5 hours
Water Resistance: IP54
Dimensions: 154 x 37 / 31.8 mm
Weight: 157g (excluding battery)
Includes: USB charging cable and car charger.
