Compact yet impressively bright, the Lighthouse Elite Mini LED Lamp offers dual functionality as both a torch and a work light. Its pocket-sized design conceals powerful lighting options suited for a variety of tasks.
Choose between a focused 55-lumen beam from a 3W LED spotlight, or flood your workspace with up to 500 lumens from a 10W COB LED. The work light has adjustable brightness settings 100% or 50% and can be dimmed by holding the power button. Enjoy up to 10 hours of spot illumination or 2 hours of full-brightness flood light.
Powered by a rechargeable 3.7V 1500mAh lithium polymer battery, it charges easily via the included USB cable. The lamp features a magnetic base for secure attachment to metal surfaces, a sturdy pocket clip for hands-free carrying, and a fold-out hook for hanging.
A reliable companion for professionals and practical use around the home or car. Supplied with a USB charging cable.
Specifications
Lighting Modes: Spot / Flood 100% / Flood 50%
Brightness Output: 55 / 500 / 250 lumens
Run Time: 10 / 2 / 10 hours
Light Source: 3W LED / 10W COB LED
Battery Type: 3.7V 1500mAh Lithium Polymer
Charging Time: 3 hours
Water Resistance: IP44
Dimensions: 106 x 40 x 13.5mm (24.5mm with clip)
Weight: 85g
Battery Capacity 1,500 mAh
Battery Voltage 3.7 V
Batteries Integral
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5023969002934
