A versatile, high-performance headlight offering up to 480 lumens with spot and floodlight functions. Easily cycle between spot high, spot low, and flood modes using the main button, or hold to adjust brightness. Use LEDs independently or together for tailored illumination.
Activate sensor mode for hands-free control—ideal when wearing gloves or working in messy environments. The tilting lamp head and adjustable strap ensure comfort and directional lighting, while the magnetic base allows attachment to metal surfaces when detached.
Powered by a rechargeable 3.7V 1400mAh Li-ion battery, it delivers up to 10 hours of runtime. A low battery indicator alerts when charging is needed. Waterproof to IPX6 and impact-rated to 1m, it’s built for tough conditions.
Perfect for home use, outdoor activities like camping, hiking, cycling, and emergency situations.
Includes: USB charging cable.
Specifications
Output: 300 / 90 / 250 / 480 lumens
Modes: Spot High / Spot Low / Flood / Both
Run Time: 3 / 10 / 3.5 / 1.45 hours
Beam Distance: 60 / 20 / 10m
Light Source: Osram P8 LED / COB LED
Battery: 3.7V 1400mAh Li-ion
Charge Time: 2–2.5 hours
Charging Port: Micro USB
Water Resistance: IPX6
Dimensions: 67 × 37 × 40mm (excluding strap)
Weight: 198g
