The Lighthouse T100FR is a versatile, high-performance inspection wand designed to light up hard-to-reach areas in vehicles, machinery, lofts, and dimly lit workspaces. It’s also ideal for outdoor activities like camping or emergency use.
Featuring a powerful 1000-lumen COB LED light that rotates up to 270°, it offers excellent illumination and wide coverage. A secondary spotlight LED provides focused, directional lighting—perfect for pinpointing specific areas.
With adjustable brightness settings of 25%, 50%, and 100%, you can tailor the light output to suit your task. Powered by a 2500mAh rechargeable Li-ion battery, the torch delivers up to 12 hours of runtime on a single charge, ensuring long-lasting performance.
Its compact, foldable design makes it easy to carry, while the magnetic base allows for hands-free use on metal surfaces. Built to withstand tough conditions, the T100FR is IP54 water-resistant and IK07 impact-resistant.
Includes: USB-C charging cable.
Specifications:
Brightness: 1000 / 500 / 250 / 200 lumens
LED Power: 10W / 2W
Beam Distance: 50m
LED Colour Temperature: 6,500K
Light Source: COB LED
Battery: Rechargeable 3.7V 2500mAh Li-ion
Max Runtime: Up to 12 hours
Charge Time: Approx. 3.5 hours
Impact Resistance: IK07
Water Resistance: IP54
Dimensions: 350 x 50 x 50mm
Weight: 257g
Battery Capacity 2,500 mAh
Battery Voltage 3.7 V
Batteries Integral
Battery Type Li-ion
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5023969012001
