Illuminate the impossible.
The Lighthouse T100WR is your ultimate inspection companion—designed to light up hard-to-reach spaces with precision and power. Whether you're an electrician, plumber, mechanic, or kitchen fitter, this slim-line, rechargeable wand is built to perform in the toughest environments.
Key Features:
Ultra-Bright & Dimmable:
Equipped with a high-power COB LED delivering up to 1000 lumens of crisp white light. Easily adjust brightness with a smooth rotary dial for floodlight or spot beam use.
Slim & Versatile Design:
The super-slim light blade fits through tight gaps, while the adjustable hook and magnetic base offer hands-free convenience. A ball joint lets you angle the light exactly where you need it.
Built for Tough Jobs:
With an IP67 waterproof rating, it can be submerged for up to 10 minutes (with the USB cover sealed). Plus, it’s impact resistant (IK08)—ready for rugged use.
Long-Lasting Power:
The rechargeable 3.7V 2500mAh Li-ion battery provides up to 12 hours of runtime and recharges in just 3.5 hours via USB-C.
Specifications:
Brightness: 1,000 / 200 lumens
LED Power: 10W / 2W
Colour Temperature: 6,500K
Light Source: COB LED
Battery: 3.7V 2500mAh Li-ion
Max Runtime: 12 hours
Charge Time: Approx. 3.5 hours
Impact Resistance: IK08
Water Resistance: IP67
Dimensions: 410 x 45 x 40mm
Weight: 291g
Includes: USB-C Charging Lead
Battery Capacity 2,500 mAh
Battery Voltage 3.7 V
Batteries Integral
Battery Type Li-ion
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5023969012018
