The Lighthouse T70R Rechargeable Inspection Lamp is an essential tool for any professional or DIY enthusiast. This versatile lamp features a powerful SMD LED that delivers an impressive 700-lumen floodlight output, perfect for illuminating large areas. Additionally, it includes a separate 120-lumen spotlight LED for focused, directional lighting when you need it most.
One of the standout features of the T70R is its 2,500mAh Li-ion battery, which provides up to 10 hours of continuous use, depending on the selected function. Whether you require a strong light for extended periods or a quick burst of brightness, this lamp has you covered. The T70R Inspection Lamp also offers a convenient swivelling design, allowing you to set the light at the perfect angle for any task. This is particularly useful for illuminating tight spaces such as cupboards, tents, and car engines. The magnetic back ensures easy attachment to various metal surfaces, adding to its flexibility. Additionally, the lamp comes with two different-sized hanging hooks that fold neatly into the body, freeing up your hands while you work. Supplied with a 1m USB C lead, the T70R is ready to go whenever you are.
Battery Capacity 2,500 mAh
Batteries Integral
Battery Type Li-ion
Web Attribute Set Torches, Headlights & Batteries
EAN Barcode 5023969011974
