With its sleek, faceted gunmetal plated design and easy-to-make single tube construction, this pen is a winner. This stylish roller ball pen will allow you to show off your turning skills. What makes this pen truly unique is the magnetic cap. The cap easily posts magnetically onto the nib and onto the top of the pen without the use of threads. It’s all done magnetically. Requires 10.5mm drill. When using a mandrel to make these pens, the 103036 bushing set will be required.
Pen Kit Classification Master
Difficulty Beginner
Drill Bit Required 10.5 mm
Bushing Set Order No. 103036
Minimum Blank Size 16 mm x 16 mm x 72 mm
Pen Type Rollerball Pen
Colour Gun Metal Grey Web Attribute Set: Project Kits
EAN Barcode 5052511073771
