The Makita 9404 has a wide 100mm belt and can be used to sand down surfaces such as table tops. Mainly used working with the grain, it is also very good at working across the grain to flatten before working with the grain to leave a clean, even finish. It is fitted with a high torque 1,010W motor and variable speed control 210-440m/min. Graphite and rubber pads cushion the underside of the belt. The housing allows flush sanding on one side.
Makita
Makita 9404 Belt Sander
| Belt Speed | 210 to 440 m/min (var) |
| Dust Collection | Dust Bag Supplied |
| Sound Power Level LwA [Uncertainty K] | 96 dB(A) [3.0 dB] |
| Corded or Cordless | Corded |
| Abrasive Belt Size | 100 mm x 610 mm |
| Sound Pressure Level LpA [Uncertainty K] | 85 dB(A) [3.0 dB] |
| Vibration Sanding [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Motor Power | 1,010 W |
| Plug Fitted | UK 3 pin plug |
| Web Attribute Set | Belt Sanders |
