Makita
Makita 9911 Belt Sander - 230V
SKU: 76014
£123.98
£103.32 Excl. VAT
  • Easy belt change
  • Flush sanding on one side
  • Automatic belt tension and tracking
  • Well designed easy to hold and use
  • Variable speed 75-270m/min
  • Efficient dust extraction
  • Quiet motor
You get a lot of tool in the box when you buy a Makita 9911 sander, with lots of features you might only anticipate getting on a much dearer machine. This is a great sander for the discerning home user or for light trade use. Supplied with sanding belt and dust bag.
This product is manufactured in the UK, at the Makita factory in Telford.
Belt Speed 75 to 270 m/min (var)
Dust Collection Dust Bag Supplied
Rating Trade/Professional
Sound Power Level LwA [Uncertainty K] 94 dB(A) [3.0 dB]
Corded or Cordless Corded
Abrasive Belt Size 75 mm x 457 mm
Sound Pressure Level LpA [Uncertainty K] 83 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.5 m/s² [1.5 m/s²]
Motor Power 650 W
Plug Fitted UK 3 pin plug
Voltage 230 V
Web Attribute Set Belt Sanders
