This versatile 150mm disc random orbit sander has a wide range of speeds with variable control (4,000-10,000 rpm). The choice of speed gives you plenty of options from fast and aggressive sanding right down to polishing. With a 3mm orbit diameter, it leaves a swirl-free finish. Dust extraction is efficient through the holes in the pad into the dust bag. It features a large rear handle with a cushioned grip and a detachable front handle; enabling you to work into a corner.
This product is manufactured in the UK, at the Makita factory in Telford.
Supplied complete with abrasive disc and dust bag.
Dust Collection Dust Bag Supplied
No Load Speed 4,000 - 10,000 rpm
Rating Trade/Professional
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 77 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 4.0 m/s² [1.5 m/s²]
Motor Power 310 W
Plug Fitted UK 3 pin plug
Web Attribute Set Random Orbit Sanders
