The 18V DBO480 Cordless palm sander gets its power from a Makita 18V LXT battery giving you powerful sanding efficiency with cordless mobility.
The DBO480 is a 1/4 sheet sander (102 x 112mm) features two sanding speeds The speed is easily changed using the one-touch control switch located next to the on/off switch; full control at your fingertips.The ergonomically designed body features a rubberised insert, minimising vibration whilst offering a comfortable and firm for better control.
The Makita DBO480 is perfect for finishing a whole range of materials. The abrasive attaches almost instantly to the hook and loop base. Alternatively, steel spring clips allow you to use standard abrasive papers.
The through-base extraction draws sanding dust through the machine into a waste bag. If preferred, the waste bag can be removed and replaced by an extractor hose for improved dust extraction.
Supplied complete with dust bag, triangle plate, abrasive paper set, dust bag nozzle, dust nozzle and punch plate.
Note: this is a body only machine supplied without batteries or charger. Part of the Makita LXT battery family.
