Makita
Makita DGA517Z Brushless Angle Grinder 125mm 18V (Body Only)
SKU: 104636
£199.98
£166.65 Excl. VAT
  • Auto Torque Drive adjusts speed and torque for maximum efficiency
  • Active Feedback Sensing Technology (AFT) prevents kickback
  • Paddle switch for ease of operation and additional safety
  • Auxiliary handle fits on either side of gearbox for greater control
  • Electric brake quickly brings wheel to a complete stop
  • Soft start reduces start-up shock, ensuring better safety
  • Brushless motor, provides more power and longer runtimes
This 18V Makita angle grinder features a brushless motor, delivering greater power and maximising battery runtimes. The Makita DGA517Z has automatic torque drive, which adjusts speed and torque depending on the load. This increased efficiency automatically gives you high speed for lighter cuts and a lower speed with more torque in heavy-duty applications.
Active Feedback Sensing Technology (AFT) prevents kickback by turning the motor off immediately should the wheel jam. A variable speed dial allows you to set the speed between 3,000 and 8,500rpm to suit various applications: cutting, grinding or sanding. XPT (eXtreme Protection Technology) protects the tool in outdoor applications or harsh environments, and gives greater protection against dust and moisture.
A rubberised soft grip minimises vibration and increases comfort and control. The paddle switch is easy to operate, and features anti-restart preventing accidental start-up if the switch is engaged when inserting a battery. The soft start eliminates any sudden jolt on start-up. An electric brake stops the disc very quickly, making this powerful machine safer to use.
The DGA517Z offers you mains performance in a cordless tool. This 125mm angle grinder scores highly for both efficiency and safety.
This is a body only machine, without batteries and charger.
Battery Voltage 18 V
Rating Trade/Professional
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 79 dB(A) [3.0 dB]
Vibration Sanding [Uncertainty K] 2.5 m/s² [1.5 m/s²]
Web Attribute Set Cordless Angle Grinders
EAN Barcode 88381854047
