Fitted with an advanced brushless motor, the DHS680 offers high performance and improved technology. The saw features Makita’s Automatic Speed Control. Heavy cuts require lower speeds with higher torque, lighter cuts need higher speeds. The saw does this automatically changing the cutting speed according to the load. The DHS680 is compact and the weight reduced by using strong magnesium alloy castings for the base, blade case and safety cover. The 165mm, 24 tooth blade tilts up to 50, with a maximum depth of cut of 57mm at 90. Twin LED job lights and a blower ensure you have a clear view of the cutting line. The saw has an electric brake, soft start and an ergonomic comfort grip. A handy built-in hook allows you hang the saw on a ladder rung, for example, when not in use.
The machine is supplied as body only without batteries, case or charger. Part of the Makita LXT 18V Family.
Battery Voltage 18 V
Max Depth of Cut @ 45º 41 mm
Max Depth of Cut @ 90º 57 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 165 mm
Sound Power Level LwA [Uncertainty K] 94 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 83 dB(A) [3.0 dB]
Saw Blade Speed 5,000 rpm
Web Attribute Set Cordless Circular Saws
