Makita
Makita DJR186Z Cordless Sabre Saw 18V (Body Only)
SKU: 102691
£113.33
£94.44 Excl. VAT
  • Multi-purpose, multi-cutting saw for wood, metal, plastic etc
  • Tool-less blade change, simple locking mechanism
  • Variable speed trigger switch with lock-off lever
  • Maximum cut in wood of 255mm with 2,900 strokes per minute
  • Ergonomically designed handle for safe and comfortable grip
  • High efficiency crank mechanism
  • Body only supplied without battery or charger
Model DJR186 is a cordless sabre or reciprocating saw. This version is body only and requires power from a Makita slide-on LXT 18V Li-ion battery. The design offers you high cutting efficiency and more durability. A sabre or reciprocating saw is an extremely useful tool. The DJR features tool-less blade change. It has a variable speed trigger and an electric brake, giving you complete control. The soft grip handle with an anti-slip elastomer wrap offers comfort and helps minimise vibration. With the wide variety of blade types available, you can cut wood, metal and plastic. With the right blade, it is possible to cut mild steel pipe, railway sleepers or pruning trees.
Battery Voltage 18 V
Rating Trade/Professional
Stroke Length 32 mm
Sound Power Level LwA [Uncertainty K] 95 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 84 dB(A) [3.0 dB]
Vibration Cutting Wood [Uncertainty K] 12.5 m/s² [1.5 m/s²]
Web Attribute Set Cordless Sabre Saws
EAN Barcode 88381806640
