Makita
Makita DPJ180Z Cordless Biscuit Jointer 18V (Body Only)
SKU: 506184
£265.98
£221.65 Excl. VAT
  • Powerful, compact, cordless biscuit jointer
  • Fence adjustable for height
  • Positive stops at 0, 45 and 90 for angle work
  • Fitted with motor current limiter and anti-restart function
  • Rotating dust nozzle can be used with dust bag (supplied) or with extraction hose
  • Spindle lock and blade cover opens for blade changing Supplied as body only
A powerful, cordless biscuit jointer with all the features and benefits of a mains machine but without a cable to restrict use. Compact and lightweight in design, it has a slim body grip for the best control. Easy to set up with a choice of six preset cutting depths, the fence has positive stops at 0, 45 and 90 for angle work. The additional front fence is adjusted accurately for height with rack and pinion locking securely. It is fitted with motor current limiter and anti-restart function. The rotating dust nozzle can be used with dust bag (supplied) or extraction hose. There is a spindle lock button and the blade cover opens for fast blade changing. Part of the 18V Makita family of tools.
Manufactured in the UK, in the Makita factory in Telford.
Supplied as body only (without batteries, charger and case).
Battery Voltage 18 V
Dust Collection Dust Bag Supplied
Rating Trade/Professional
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 73 dB(A) [3.0 dB]
Cutter Speed 10,000 rpm
Web Attribute Set Cordless Biscuit Jointers
