{"product_id":"makita-dsp600zj-brushless-plunge-saw-18v-makpac-body-only","title":"Makita DSP600ZJ Brushless Plunge Saw 18V \u0026 Makpac (Body Only)","description":"\u003cp\u003eThe Makita DSP600ZJ Plunge Saw uses two 18V LXT batteries to drive its powerful 36V brushless motor. This combination gives greater power, speed and runtime offering a performance comparable to, if not better than, a corded equivalent.\u003c\/p\u003e\u003cp\u003eThe unit has a soft start and a dial-in variable speed control. In addition, the saw features Automatic Torque Drive Technology (ADT) Technology, which automatically adjusts cutting speed and torque throughout the cut, for superior performance. A built-in depth stop allows you to make a shallow 2-3mm preliminary cut prior to cutting fully through the workpiece for a cleaner, splinter-free finish.\u003c\/p\u003e\u003cp\u003eThe DSP600ZJ has a large 56mm cutting capacity at 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, and bevel angle cutting capability of -1\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to +48\u003cspecial id=\"8\"\u003e\u003c\/special\u003e with positive stops at 22.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003eand 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e. When used with a rail system (available separately), this saw is ideal for use on site or in a workshop for highly accurate, clean cuts in sheet material. Supplied with Makpac 4 case and inlay.\u003c\/p\u003e\u003cp\u003eThe machine is supplied as body only without batteries or charger. Part of the Makita LXT 18V Family.\u003c\/p\u003e","brand":"Makita","offers":[{"title":"Default Title","offer_id":54118298452315,"sku":"104522","price":429.98,"currency_code":"GBP","in_stock":false}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/104522_xl.jpg?v=1789774298","url":"https:\/\/www.axminstertools.com\/products\/makita-dsp600zj-brushless-plunge-saw-18v-makpac-body-only","provider":"Axminster Tools","version":"1.0","type":"link"}
