Makita
Makita DSS501Z Cordless Circular Saw 18V (Body Only)
SKU: 506177
£156.98
£130.82 Excl. VAT
  • Compact 18V Li-Ion saw
  • Very well positioned rear and front handles
  • 51mm cut at 90, 35mm at 45
  • Fitted with work light
  • Makita 'star' technology compatibility
  • Part of Makita 18V Li-Ion family
  • Supplied as body only
  • 3 year Makita warranty available (registration required)
A compact 18V Li-Ion saw that has a maximum depth of cut of 51mm at 90 and 35mm at 45. This machine is part of the Makita 18V Li-Ion system and will quickly and easily cut through material. The machine has a well positioned rear and front handle that is in line with the saw so that little effort is needed to guide it through the material being cut. Fitted with a 16 tooth, 136mm blade, there is also a light to help you see your cutting line. Supplied as body only.
Please note: model number starting with letter 'D' has a 'star' imprint on the connector plate enabling full communication with a Makita battery also with a 'star'.
Battery Voltage 18 V
Max Depth of Cut @ 45º 35 mm
Max Depth of Cut @ 90º 51 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 136 mm
Sound Power Level LwA [Uncertainty K] 103 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 92 dB(A) [3.0 dB]
Saw Blade Speed 3,600 rpm
Web Attribute Set Cordless Circular Saws
