This is a well balanced, light yet powerful 18V saw from Makita for rip and cross-cut work. The power comes from Lithium Ion batteries which are up to 40% lighter than metal hydride batteries, deliver better service life and are lighter for the tool. The TCT 24 tooth, 165mm blade gives a maximum depth of cut of 57mm and a 45 cut of up to 40mm. This well designed saw has a sturdy baseplate which is easy to angle, comfortable handles, electric brake and LED job light. It is part of the Makita 18V li-Ion family.
Supplied as body only with side fence (without batteries, charger or case).
Please note: model number starting with letter 'D' has a 'star' imprint on the connector plate enabling full communication with a Makita battery also with a 'star'.
Battery Voltage 18 V
Max Depth of Cut @ 45º 40 mm
Max Depth of Cut @ 90º 57 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 165 mm
Sound Power Level LwA [Uncertainty K] 101 dB(A) [3.0 dB]
Battery Type Li-ion
Corded or Cordless Cordless
Sound Pressure Level LpA [Uncertainty K] 91 dB(A) [3.0 dB]
Saw Blade Speed 3,700 rpm
Web Attribute Set Cordless Circular Saws
