Using the powerful 18V Li-Ion system battery, Makita has developed a Multi-Tool that will give you total freedom for working almost anywhere. Named Multi-Tools, they are a total tool kit in one tool, all you need to do is change the accessory. This Multi-Tool will cut, sand, rasp, scrape, polish and more, plus a host of different accessories are available to cover almost any task. The tool is smooth running using oscillation action and speed is selected on the control dial depending on the task. Accessories can be fitted in a full 360
Makita
Makita DTM50Z Cordless Multi-Tool 18V (Body Only)
| Battery Voltage | 18 V |
| Sound Power Level LwA [Uncertainty K] | 95 dB(A) [3.0 dB] |
| Batteries Included | Body Only Tool |
| Battery Type | Li-ion |
| Corded or Cordless | Cordless |
| Sound Pressure Level LpA [Uncertainty K] | 84 dB(A) [3.0 dB] |
| Vibration Sanding [Uncertainty K] | 2.5 m/s² [1.5 m/s²] |
| Web Attribute Set | Cordless Oscillating Tools |
