{"product_id":"makita-hs7601j-190mm-circular-saw","title":"Makita HS7601J 190mm Circular Saw","description":"\u003cp\u003eThis thoughtfully designed 190mm saw allows you to cut to a maximum of 66mm. It has a 1,200W high specification and powerful motor. The flat motor housing lets the saw stand upright and stable when changing the blade. The heavy-duty base, cut from aluminium plate, forms a solid base adding to the overall quality. Depth adjustment simplified using a single action lever. The rubber moulded grip greatly increases comfort when in use. The guarding is die-cast aluminium.\u003c\/p\u003e\u003cp\u003eThis product is manufactured in the UK, at the Makita factory in Telford.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003e\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied with general purpose 12tpi TCT saw blade, rip fence, dust extraction nozzle, hex key wrench and MAKPAC (Type 4) connector case and inlay.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Makita","offers":[{"title":"Default Title","offer_id":54117979423067,"sku":"101601","price":141.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/101601_xl.jpg?v=1790081826","url":"https:\/\/www.axminstertools.com\/products\/makita-hs7601j-190mm-circular-saw","provider":"Axminster Tools","version":"1.0","type":"link"}
