Makita
Makita LS0815FL 216mm Mitre Saw
SKU: 506275
£414.98
£345.82 Excl. VAT
  • Soft grip carrying handle for easy transportation
  • Integrated laser marker
  • LED job light
  • Sliding sub-fence (left hand side only)
  • High cutting capacity
The LS0815 is a 216mm (8.5) cost-effective sliding compound mitre saw with an integrated laser marker, LED job light and a maximum mitre range of 50–60. Positive stops make mitre and repeat settings simple and quick (0, 15, 22.5, 31.6, 45). Twin steel bars with linear ball bearings give you a smooth and precise sliding action. A powerful 1,400W motor with a 'soft start' feature provides power together with a soft grip handle for easy transportation and, as it only weighs 14.2kg, it’s relatively easy to move around the workshop or site. A sliding sub-fence is fitted on the left hand side as well as work supports on each side.
Supplied with dust bag, triangular rule, TCT blade and a 2.5m power cord.
Bevel Angle Range 48 - 0 - 5
Dust Collection Dust Bag Supplied
Mitre Angle Range 50 - 0 - 60
Overall L x W x H 755 mm x 450 mm x 488 mm
Rating Trade/Professional
Spindle Lock Standard Feature
Blade Diameter 216 mm
Sound Power Level LwA [Uncertainty K] 110 dB(A) [3.0 dB]
Corded or Cordless Corded
Blade RPM 5,000 rpm
Sound Pressure Level LpA [Uncertainty K] 87 dB(A) [3.0 dB]
Motor Power 1,400 W
Voltage 230 V
Web Attribute Set Mitre Saws Mains Powered Globale Group: low-margin-eu
