{"product_id":"makita-ls1219l-305mm-mitre-saw-with-laser-230v","title":"Makita LS1219L 305mm Mitre Saw With Laser 230V","description":"\u003cp\u003eThe 305mm Makita LS1219L mitre saw features a motor unit mounted on twin, front facing, steel guide bars. This arrangement allows you to position the saw against a wall thereby gaining valuable floor space, especially when working on site. This dual-bevel, sliding compound mitre saw offers large capacity, accuracy and a reduced footprint. Dust extraction comes in the form of a dust bag or a dual point, adaptor hose for connection to a vacuum extractor. Using the hose adaptor and vacuum means extraction takes place from both behind the blade and below the table.\u003c\/p\u003e\u003cp\u003eThe motor has both soft start and electronic speed control. An electric brake brings the blade to an almost immediate halt on releasing the trigger.\u003c\/p\u003e\u003cp\u003eA laser projects a line across the workpiece as a cutting guide. The laser is adjustable to shine on the left or right of the blade whichever is most convenient. The saw cuts mitres from 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to 60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e both left and right, with indexed stops at 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 15\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 22.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 31.6\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 60\u003cspecial id=\"8\"\u003e\u003c\/special\u003e (left or right). The bevel capacity is from 0\u003cspecial id=\"8\"\u003e\u003c\/special\u003e to 48\u003cspecial id=\"8\"\u003e\u003c\/special\u003e both left and right. The LS1219L’s large aluminium base features additional pull-out supports when cutting long timbers.\u003c\/p\u003e\u003cp\u003eSupplied with TCT saw blade, dust bag, extraction connector, vertical hold-down and maintenance tools.\u003c\/p\u003e","brand":"Makita","offers":[{"title":"Default Title","offer_id":54118387482971,"sku":"106671","price":949.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/106671_xl.jpg?v=1790081844","url":"https:\/\/www.axminstertools.com\/products\/makita-ls1219l-305mm-mitre-saw-with-laser-230v","provider":"Axminster Tools","version":"1.0","type":"link"}
