Makita
Makita PJ7000 Biscuit Jointer
SKU: 501866
£237.98
£198.32 Excl. VAT
  • Precise plunge in vertical, horizontal or angled work faces
  • Easy locking fence, clear central mark
  • Tilting base with pre-set 0, 45 and 90 angles
  • Rack and pinion front fence adjustment
  • Six pre-set depth stops with fine adjuster, suitable for flush cuts
  • Dust extraction via the dust bag or 30mm hose outlet
  • Spindle lock for easy blade change
  • Supplied with dust bag, TCT blade and storage case
This machine will make the jointing process simple. It is compact, light in weight and well thought out with adjustable fences and clear scales. It plunges smoothly in vertical, horizontal or angled work faces. The fence is clearly marked so you can line up the cut. It has a tilting base with quick locking lever and positive stops at 0, 45 and 90. The self-aligning front fence is set for height quickly and is finely adjusted with the rack and pinion adjuster wheel. Blade depth is controlled with a swivelling stepped turret for quick control. There are six stops which can be adjusted for different biscuit and fitting depths, this can be adjusted more finely with a lockable screw if required. Dust extraction is via the supplied dust bag or a hose can be fitted to the 30mm outlet. A blade lock aids blade changing.
Complete with TCT blade, dust bag, slip on fence plate, spanner and storage case
Dust Collection Dust Bag Supplied
Rating Trade/Professional
Blade Diameter 100 mm
Sound Power Level LwA [Uncertainty K] 97 dB(A) [3.0 dB]
Corded or Cordless Corded
Sound Pressure Level LpA [Uncertainty K] 86 dB(A) [3.0 dB]
Motor Power 700 W
Cutter Speed 10,000 rpm
Voltage 230 V
Web Attribute Set Biscuit Jointers
