The WST06 stand is compatible with the following Makita mitre saws: LS0714, LS0815, LS1016, LS1018, LS1019L, LS1219L, LS1216, LS1040, DLS713 and MLS100. This folding stand with twin castors, carry handle and a weight of only 18kg is easy to transport or store (with or without the saw attached). Once unfolded, an adjustable levelling foot prevents the stand from wobbling on uneven floors or ground. Quick release (tool-less) locking levers enable you to quickly install or remove your mitre saw without the need for additional tools. The sliding rail lets you position anywhere along the bed of the stand. The arms extend to a maximum of 2,550mm. One arm features a roller whilst the other has a material stop for repeat cuts.
Overall L x W x H Open: 1,150 mm x 750 mm x 850 mm Collapsed: 1,270 mm x 270 mm x 250 mm
Web Attribute Set Mitre Saw Stands Globale Group: low-margin-eu
