{"product_id":"makita-sp6000j1-plunge-saw-2-x-1-5m-rails-and-connectors","title":"Makita SP6000J1 Plunge Saw \u0026 2 x 1.5m Rails and Connectors","description":"\u003cp\u003eThis plunge saw from Makita is supplied with 2 x 1.5m rails, connectors and storage case for the saw.\u003c\/p\u003e\u003cp\u003eWhy buy a plunge saw? Simple, it will allow you to cut a very precise straight line with ease and this saw is so well built with many features for the most precise cut when ripping and crosscutting.\u003c\/p\u003e\u003cp\u003eThe rail guides the saw perfectly, the rail has an anti splinter strip for a clean cut and the anti slip stips mean you do not even have to clamp the rail on most surfaces but additional rail clamps are available if required. The saw can also plunge for cut-outs if required. Driven by a powerful 1,300W motor (overload protected) with constant electronics to maintain speed under load for a very smooth cut. A variable speed dial allows you to select correct speed for material being cut. With a wide cut range and clear setting it can cut up to 55mm depth and 39mm at 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, a 2mm scoring cut can quickly be made before the full depth cut, height and angles (-1\u003cspecial id=\"8\"\u003e\u003c\/special\u003e - 48\u003cspecial id=\"8\"\u003e\u003c\/special\u003e) are simply set with thumb screws, with positive stops for -1\u003cspecial id=\"8\"\u003e\u003c\/special\u003e, 22.5\u003cspecial id=\"8\"\u003e\u003c\/special\u003e and 45\u003cspecial id=\"8\"\u003e\u003c\/special\u003e.\u003c\/p\u003e\u003cp\u003eThis product is manufactured in the UK, at the Makita factory in Telford.\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003e\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e\u003cp\u003e\u003cspecial id=\"22\"\u003e\u003c\/special\u003eSupplied with 2 rails and connectors that have a replaceable splinter guard, anti-slip strips on the underside and top running strips for a smooth glide, 48T TCT blade and Systainer storage case with inlay.\u003cspecial id=\"23\"\u003e\u003c\/special\u003e\u003c\/p\u003e","brand":"Makita","offers":[{"title":"230 V","offer_id":54116499685723,"sku":"701428","price":469.98,"currency_code":"GBP","in_stock":true},{"title":"110 V","offer_id":54116499718491,"sku":"702767","price":449.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/701428_xl.jpg?v=1790081854","url":"https:\/\/www.axminstertools.com\/products\/makita-sp6000j1-plunge-saw-2-x-1-5m-rails-and-connectors","provider":"Axminster Tools","version":"1.0","type":"link"}
