This is a Class L extractor which means it removes 99.0% of dust with the limit value for occupational exposure of >1.0mg/m. It is suitable for processes involving mica, china clay and gypsum, for example. The 30 litre capacity drum is stainless steel. It features an innovative storage solution for the 3.5m length of hose putting it neatly out of harm’s way when not in use. A washable PET cartridge filter protects the turbine from fine dust and debris. With the push and clean system it takes just seconds to clean the filter. A fleece filter bag picks up most debris without damaging the filter bag. The 230V version features a power take-off with an automatic On/Off function. Once connected, switching the power tool on or off automatically starts and stops the extractor. An integrated carry handle makes lifting and tilting of container easy and convenient, and the wheeled base gives full mobility.
Overall L x W x H 395 mm x 390 mm x x 635 mm
Rating Trade/Professional
Corded or Cordless Corded
Cable Length 10 m
Max Capacity Dry 30 litre
Airflow Volume 3,600 litre/min
Sound Pressure Level LpA [Uncertainty K] 72 dB(A) [3.0 dB]
Motor Power 1,000 W
Plug Fitted UK 3 pin plug
Web Attribute Set Vacuum Cleaners - Wet & Dry Globale Group: low-margin-eu
