{"product_id":"matsui-pico-scriber-gauge","title":"Matsui PICO Scriber Gauge","description":"\u003cp\u003eThe PICO gauge has its origins in engineering and machining. When it comes to woodwork this small marking gauge offers you unparalleled accuracy (pun intended).\u003c\/p\u003e\u003cp\u003eThe PICO gauge is designed to be a small, handy marking and measuring device, easily taken to the work.\u003c\/p\u003e\u003cp\u003eIts main function is similar to that of a combination square, but with far greater precision and repeatable precision. The PICO gauge can be set to an accuracy of 0.1mm. This tool will give you a perfect parallel edge when measuring and marking. The reference bar is 50mm long by 3.8mm deep for maximum support. You can use it with items of various shapes, including parallel, vertical, cylindrical, objects with rounded corners, etc.\u003c\/p\u003e\u003cp\u003eSuitable for woodworking, metal work and all manner of layout operations.\u003c\/p\u003e\u003cp\u003eMeasuring or scribing depth max. 100mm with 0.1mm vernier scale. The back of the gauge has a 50mm scale for use as a depth gauge. Made of hardened SUS420J2 stainless steel for long life and corrosion resistance.\u003c\/p\u003e\u003cp\u003eSize: approx L170mm x W51mm\u003c\/p\u003e\u003cp\u003eWeight: approx. 90g　\u003c\/p\u003e\u003cp\u003eMade in Japan.\u003c\/p\u003e","brand":"Tools from Japan","offers":[{"title":"Default Title","offer_id":54118466126171,"sku":"108814","price":56.78,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/108814_xl.jpg?v=1789781187","url":"https:\/\/www.axminstertools.com\/products\/matsui-pico-scriber-gauge","provider":"Axminster Tools","version":"1.0","type":"link"}
