If the recipe calls for 1/4-tsp, 1/2-tsp, 1-tsp or 1-tbls, then one of these spoons is the answer. This project kit lets you create these must-have kitchen essentials. The set includes four of the most common measuring spoon sizes. They sit on a handy chrome ring and can be detached for individual use. These spoons are plated with durable, food safe chrome and are easy to hand wash. The measurements are marked in the metal and will not wear off. Easy to make on a pen mandrel with 7mm tubes. Drill bit required 7mm, recommended bushing set 107897.
Difficulty Intermediate
Drill Bit Required 7 mm
Bushing Set Order No. 107897
Minimum Blank Size 16 mm x 16 mm x 88 mm (each)
Web Attribute Set Project Kits
