Designed for superior protection and efficiency, the Metabo ASR 35 M ACP meets EU M Class dust standards and is perfect for continuous dust extraction in workshops and on construction sites. Suitable for dust with OEL ≥ 0.1 mg/m³; efficiency 99.99%.It's particularly effective at removing fine concrete and rock dust, and can handle both wet and dry materials with commercial-grade performance.
AutoCleanPlus technology helps reduce cost and downtime by automatically cleaning the MPulse filters during operation. If suction performance dips, the system vibrates the filters to restore airflow. When vacuuming liquids, it automatically shuts down once full capacity is reached. An automatic trailing feature ensures the suction hose is completely emptied.
Built for durability and convenience, the vacuum includes large wheels and lockable castors for smooth mobility, plus a cable winding system, accessory storage compartment, and a power socket with auto start-stop for connected tools.
Included in the package:
1 x 4m Anti-Static Suction Hose (Ø35mm)
1 x Connection Bush (Ø41mm)
1 x Handle Adaptor
2 x Plastic Suction Pipes
2 x Polyester Filter Cassettes (M Class)
1 x PE Filter Bag
1 x Crevice Nozzle
1 x Floor Nozzle (Ø300mm)
Technical specifications:
Input Power: 1,400W
Capacity: Wet/Dry: 35 litres
Maximum Air Flow: 4,380L/min
Vacuum Pressure: 248 mbar
Suction Hose Diameter: 35mm
Weight: 16kg
Overall L x W x H 55 x 40 x 55 cm
Sound Power Level LwA [Uncertainty K] 69 dB(A)
Corded or Cordless Corded
Cable Length 8 m
Max Capacity Dry 35 litre
Airflow Volume 4,380 litre/min
Sound Pressure Level LpA [Uncertainty K] 69 dB(A)
Motor Power 1,400 W
Plug Fitted UK 3 pin plug
Manufacturer Part Number 602058380
Web Attribute Set Vacuum Cleaners - Wet & Dry
EAN Barcode 4007430312624
