A selection of 19 good quality metric, high speed steel ground drill bits for drilling most metals, wood and plastics. When drilling, increased friction and heat can cause bits to lose their hardness but the high speed steel makes these bits more resistant to wear. The grinding process adds to the rigidity, makes for a clean cut and they'll hold their edge for longer.
Suitable for wood and manmade boards, some plastics, steel and cast steel, alloyed and unalloyed, grey cast iron, malleable cast iron, ductile cast iron, sintered iron, nickel silver, graphite, non-ferrous metals, plastic; Up to 900 N/mm² tensile strength.
Sizes range from 1-10mm in 0.5mm increments, housed in an indexed drill holder for easy selection. Precision ground for a fast clean cut. Supplied in a strong plastic case.
DIN 338, type N with 135° crosswise grinding
Web Attribute Set Drill Bit Sets
EAN Barcode 4007430332356
