{"product_id":"microjig-bladeclean-blade-bit-cleaning-system","title":"MICROJIG BLADECLEAN Blade \u0026 Bit Cleaning System","description":"\u003cp\u003eKeep your cutting tools at their best with the Microjig BLADECLEAN\u003cspecial id=\"10\"\u003e\u003c\/special\u003e Blade \u0026amp; Bit Cleaning System. Dirty blades and router bits place additional strain on machinery and are often mistaken for being dull. In many cases, a thorough clean is all that's needed. With BLADECLEAN\u003cspecial id=\"10\"\u003e\u003c\/special\u003e, you can clean an entire side of a circular saw blade in a single motion, making maintenance fast and efficient.\u003c\/p\u003e\u003cp\u003eSuitable for circular saw blades up to 305mm (12\u003cspecial id=\"32\"\u003e\u003c\/special\u003e) in diameter, the system features industrial grade aluminium oxide cleaning pads that reach into every nook and cranny of the blade. The magnetic handle securely attaches to the blade, keeping your hands away from sharp teeth and cleaning fluids for added safety.\u003c\/p\u003e\u003cp\u003eThe included router bit holder accommodates up to five router bits at once, making it easy to clean multiple cutters in a single session. The locking lid features an additional well for storing and soaking the bits. Compatible with 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e, 1\/2\u003cspecial id=\"32\"\u003e\u003c\/special\u003e, 6mm, 8mm and 12mm shank sizes, it uses dedicated scouring discs to thoroughly clean even intricate profiles.\u003c\/p\u003e\u003cp\u003eFeaturing integrated seals to reduce cleaning fluid evaporation, the BLADECLEAN\u003cspecial id=\"10\"\u003e\u003c\/special\u003e system is an efficient saw blade cleaner that makes woodworking tool maintenance quicker, safer and more effective. By keeping saw blades and router bits free from debris and dirt, it helps extend tool life and maintain optimum cutting performance.\u003c\/p\u003e\u003cp\u003eSupplied with BLADECLEAN\u003cspecial id=\"10\"\u003e\u003c\/special\u003e cleaning well, magnetic handle, wire brush, cleaning discs, rotary tool mandrel.\u003c\/p\u003e\u003cp\u003ePlease note, the BLADECLEAN\u003cspecial id=\"10\"\u003e\u003c\/special\u003e features seals to prevent evaporation of cleaning fluid, but is not water tight. It should be kept upright during use and storage to prevent spilling.\u003c\/p\u003e","brand":"MICROJIG","offers":[{"title":"Default Title","offer_id":54118868156763,"sku":"114576","price":95.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114576_xl.jpg?v=1789795022","url":"https:\/\/www.axminstertools.com\/products\/microjig-bladeclean-blade-bit-cleaning-system","provider":"Axminster Tools","version":"1.0","type":"link"}
