{"product_id":"microjig-grr-ripper-100-3d-pushblock","title":"MICROJIG GRR-RIPPER 100+ 3D Pushblock","description":"\u003cp\u003eDesigned to help protect hands and fingers while improving control and accuracy, the Microjig GRR-RIPPER\u003cspecial id=\"10\"\u003e\u003c\/special\u003e 100+ 3D Pushblock is an essential addition to any woodworking workshop. Suitable for everyone from beginners to experienced professionals, it provides safe, precise material handling that helps prevent accidental blade contact while delivering cleaner, more consistent cuts.\u003c\/p\u003e\u003cp\u003eThe included SafeRip Kit helps maintain the ideal distance from the blade, allowing material to pass safely through the cut while reducing the risk of kickback. It also ensures you never cut into the centre leg of the pushblock. Simply set the rip fence on your machine for your desired cut and position the centre leg accordingly. This allows you to maintain control of both the main workpiece and the offcut throughout the cut for greater safety, stability and helps to prevent blade burn.\u003c\/p\u003e\u003cp\u003eApplying three-directional force simultaneously, the GRR-RIPPER\u003cspecial id=\"10\"\u003e\u003c\/special\u003e 100+ pushes downward to control the workpiece and minimise kickback, inward to keep the stock firmly against the fence, and forward to ensure smooth, controlled feeding. The legs and main body maintain a constant 90° angle, allowing it to be used on its side for applications such as bandsaw resawing.\u003c\/p\u003e\u003cp\u003eIts high friction, non-slip grip securely holds a wide range of materials, including hardwoods, plywood, plastics, aluminium and solid surface materials. The powerful grip allows you to guide material over the cutter head with minimal downward pressure, improving both comfort and control. Easy to clean and maintain, the grip helps prevent slippage and ensures consistent results.\u003c\/p\u003e\u003cp\u003eBuilt-in balance support keeps workpieces stable and square, making it easier to handle small, delicate or awkward cuts with confidence. The GRR-RIPPER\u003cspecial id=\"10\"\u003e\u003c\/special\u003e 100+ allows you to cut pieces as small as 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e x 1\/4\u003cspecial id=\"32\"\u003e\u003c\/special\u003e on a table saw without re-adjusting the fence, making it ideal for detailed work, template routing and resawing thin material.\u003c\/p\u003e\u003cp\u003eSuitable for use on a wide range of woodworking machinery, including table saws, router tables, jointers and bandsaws, the GRR-RIPPER\u003cspecial id=\"10\"\u003e\u003c\/special\u003e 100+ 3D Pushblock delivers greater safety, control and confidence across countless workshop applications.\u003c\/p\u003e","brand":"MICROJIG","offers":[{"title":"Default Title","offer_id":54118869205339,"sku":"114587","price":56.98,"currency_code":"GBP","in_stock":true}],"thumbnail_url":"\/\/cdn.shopify.com\/s\/files\/1\/0962\/0652\/0667\/files\/114587_xl.jpg?v=1789795111","url":"https:\/\/www.axminstertools.com\/products\/microjig-grr-ripper-100-3d-pushblock","provider":"Axminster Tools","version":"1.0","type":"link"}
