MICROJIG
MICROJIG MATCHFIT Relief 1/4STR Router Bit 1/4SHK
SKU: 114591
£28.98
£24.15 Excl. VAT
  • Precision relief router bit designed for MATCHFIT dovetail track preparation
  • Removes up to 55% of waste material before dovetail routing
  • Reduces stress on dovetail bits and extends tool life
  • Built-in roundover helps minimise tear-out and sanding
  • Laser-etched depth guide enables quick and accurate setup
  • Produces smoother clamp tracks for improved hardware movement
  • Extra-wide shoulder helps reduce vibration and routing noise
  • Ideal for creating clean MATCHFIT dovetail grooves in sheet materials
The MICROJIG MATCHFIT Relief 1/4 Straight Router Bit is a specialised relief router bit designed to prepare material for creating smooth, accurate MATCHFIT dovetail tracks. Used before the MATCHFIT Dovetail Router Bit, this groove relief bit removes up to 55% of waste material, reducing strain on the dovetail cutter while improving cut quality and extending bit life. Featuring a built-in roundover and laser-etched depth guide, it helps create cleaner grooves with less tear-out and sanding, making it an essential clamp track router bit for precision woodworking applications.
Web Attribute Set Straight Router Cutters
