The MICROJIG ZEROPLAY 2-Step Plunge Bit 1/4 Shank is a specialised plunge router bit designed to create accurate stepped holes, counterbores and slots in a single operation. Ideal for jig making, sled construction and hardware installation, this precision slot cutting bit helps eliminate guesswork by producing the correct mounting holes for ZEROPLAY, MATCHFIT and other hardware systems. With its two-step cutting design and patented radius flair, it delivers clean, consistent results while reducing setup time and improving accuracy for adjustable joint routing applications.
