This Mini 24kt Gold Keychain Pen Kit will create a unique, unusual and practical design. Only 82.5mm long, this clever little twist pen is always conveniently at hand whenever you need a pen. The 24kt gold plating uses the more durable premium rack plating process and further durability comes from an epoxy coating. Requires 7mm drill. When using a mandrel to make these pens, the 101667 bushing set will be required.
This pen uses refill 101793.
Pen Kit Classification Scholar
Difficulty Beginner
Drill Bit Required 7 mm
Bushing Set Order No. 8.5mm O/D (as supplied with mandrel) (100793)
Minimum Blank Size 19 mm x 19 mm x 90mm
Pen Type Twist Pen
Colour Gold Web Attribute Set: Project Kits
EAN Barcode 5052511096534
